Constant name has question mark inserted automatically
I have placed a DBL constant on my Block Diagram with the name "PrevFlow_sccm".  As soon as I leave text editing mode, this is changed to "P?revFlow_sccm".  Note the question mark.  I know the software is trying to tell me something but I cannot understand it.
I thought it might be a duplicate name warning but nothing turns up in the same VI with that name.
Any ideas?
(3,292 Views)
I tried it without the "_" as "PrevFlow sccm".
It still gets changed to "P?revFlow sccm".
(3,290 Views)
Accepted by topic author wildcatherder
I deleted that constant and created another from scratch.  It worked OK.
The other constant had been inside a cluster constant.  I pulled it outside the cluster constant before attempting to edit it.  Apparently, that's not good enough.
(3,280 Views)
Where did the control inside the cluster come from originally. I wonder if it has some unicode in it.
(3,274 Views)
