Constant wait cursor when editing with LVOOP
Hi Marc A,
Is there anyway you could post a small piece of your code that reproduces this behavior?
I might indeed be a bug, but to get any information from R&D, I will need to be able to reproduce the behavior here.
Have a great day,
Chris V
Message 21 of 42
(1,086 Views)
I've tried opening a couple of the classes outside of the project to get something to show, but it doesn't cause the problem. I can't attach the whole project here, so I suppose the best way would be to contact support and send it to someone there to look at. I could upload it somewhere and PM you a link if you wanted to look at it first.
Message 22 of 42
(1,080 Views)
Hi Mark A,
Yes, at this point, contacting support would probably be best (assuming you have a support contract).  Just visit ni.com/support.
Have a great day,
Chris V
Message 23 of 42
(1,063 Views)
Mark,
Do you use a lot of re-entrant VIs?
Message 24 of 42
(1,055 Views)
Not really. I made a handful run inline, but I've dealt with this problem since before I went through and did that.
Message 25 of 42
(1,053 Views)
Marc...
I fear I must join you in this misery...  😞
I now face similar symptoms.  Everything I do slows the entire PC down to a crawl..
The only applications that are open are Outlook, Word and a couple of command prompts which were closed before I noticed the slow-down.
It's been behaving slowly since Monday.  But as I add more code, it is becoming more painfully slow.
I haver used LVOOP on 2 other projects before and did not notice any development speed issues..  This is the first time I experience that.
Message 26 of 42
(1,033 Views)
I contacted support and sent my project. The person I talked to spent several days with it and although he saw the same issue, was not able to determine the cause. It was then sent to R&D. They think it has to do with type propagation. It's only been getting worse for me, and really starting to annoy me.
A CAR has been filed, so now all I can do is wait to hopefully get a solution soon.
Message 27 of 42
(1,029 Views)
Do you have the CAR # and the CAR description?
Ben
Message 28 of 42
(1,025 Views)
Thanks Marc
Message 29 of 42
(1,022 Views)
I thought I'd post what happens when I edit anything of the block diagram (remove a wire, add a function as basic as add or subtract).
The program hangs and if I click on anything I get blank windows until it returns from the twilight zone.
I also notice spikes in CPU performance.
Inerting a new state in a Type Def enum:
Adding a VI on the block diagram:
Message 30 of 42
(1,016 Views)
