Constructor names for Simple Task Monitor
In the .NET example Simple Task Monitor.vi, where does one find the correct strings to wire to the constructor? Should I be able to right-click on something to get the choices available, or is there a listing somewhere with names and descriptions? See attached for illustration.
Peg
(3,791 Views)
Each .NET constructor is defined by the programmer.  In this case, the programmer is Microsoft, so the best place to look is their website.  I found this link
http://msdn.microsoft.com/en-us/library/system.diagnostics.performancecounter_members.aspx
This shows you the constructors and methods of the PerformanceCounter.
(3,770 Views)
