Cont Acq&Graph Voltage-Analog SW Trigger.vi
can thus example be modified so that its is sending out a wafeform, say a pulse for example; for analysis on an external scope?
i have been having problems generating a pulse output with my 6008, apparently it does not support hadware timin, so im wondering if
i can overcome this with the config, but in reverse? i.e using software timing
(2,606 Views)
This example does not generate a signal on analog output channels
It acquires a signal on its analog input channels
Look at example vi's you will find in this folder
Find examples>>Hardware input/output>> DAQmx>> Analog generation and choose suitable analog generation vi from that folder
(2,603 Views)
