Context Help listing numerics for parameters
How do I remove the numerics in the context help where its listing [0] - [9] for each parameter?  I checked under Tools Options several times and I don't see where to remove the numeric from the parameter description.
(1,396 Views)
Hi richjoh,
  1. Create a backup of your LabVIEW.ini file.
  2. Delete the LabVIEW.ini file.
  3. Start LabVIEW and check if those numbers are gone…
(I guess it's a key in the LabVIEW.ini, but forgot which one…)
(1,380 Views)
Accepted by topic author richjoh
Options->VI Server
(1,379 Views)
Thanks, learned something new today.  I was using scripting and never knew.  I just don't like the look of the numerals next to the control names.
(1,332 Views)
