Continous Digital output express vi gives error -200609
Using Express vi to generate continuous output on two digital ports of NI USB-6341 - extremely basic:
To test, I simply right-click create a control at the data input of the express-vi and types in some data manually.
There are two digital lines dev1/port0/line0 and dev1/port0/line0 so I would expect this input to be an array of two digital waveforms each with one line of data. Right?
Below  is what it looks like and the error I get. Sample rate is set at 1kHz.
In the express vi, #samples to read is set at 4 (as wfm has) or 1k - it gives the same error.
  1. How can I fix this without going _inside_ the generated express code and change the buffer size, which I would like to avoid.
  2. Is the express vi generator broken for this particular - yet very simple and basic setup?
(3,297 Views)
Accepted by topic author heel
The error is quite clear.  You have to give at least 2 samples.  So change your waveform data to have a second data point for each digital waveform.  You can just make it the same as the first data point.
(3,281 Views)
Thanks crossrulz,
Time evolves vertically not horizontally in a digital waveform control/indicator - as I implicitly assumed.
then the express vi works. Thanks for the tip
(3,273 Views)
