Continuous Measurements in I2C (USB8452)
Greetings,
I am a newbie on LabVIEW, therefore I would like to apologize for any obvious question or mistake that you may found in the vi. I am trying to commuinicate with a hall effect magnetic sensor (AK8963) by I2C using the USB 8452. I am able to cummunicate and wirte in all the registers, however, I am unable to measure continous data from the sensor. I have to press continous measurements, then stop, then play in order to get different values at diferent times. Hence, I would like to ask for any help in order to measure and write on the registers in a continous manner.
I would to thanks in advance.
(2,322 Views)
You could use a While Loop for continuous measurements: Tutorial: For Loops and While Loops
(2,285 Views)
