Continuous Sound card Output in Labview 8.0
I am trying to write a VI that outputs a modulated PAM and QAM signal the soundcard.
I am unable to get a continous periodic PAM or QAM signal out of the the soundcard though.  I have tried several different approaches all with the same results.  Currently I am trying this by creating subvis that gennerate the particular waveform and return the signal to the calling vi.  I modeled these subvis after the internal library functions that gennerate a perfect sine and square wave.
Do you know of anyway tweek these subvis so that the fillal soundcard output is continous?
Attached is the current code.
<script></script>-Kenny
(2,679 Views)
Kenny,
Are you primarily having problems generating a continuous signal or getting the soudcard to play continuously?
Simon H
(2,662 Views)
