12-16-2009 05:25 AM
Can i have full speed (12MS/s) continuous acquisition (input or output) with usb-8451 ?
What is its on-board memory FIFO size ?
12-17-2009 05:08 AM - edited 12-17-2009 05:09 AM
The NI USB-8451 device has a microntroller unit (MCU) with 2304 bytes of internal RAM and 16 kilobytes of flash memory. The flash memory contains the firmware and is not user accessible. The RAM is used as a USB buffer and is cleared when the device is powered off. And as it says in the specs you can use this device with USB Full Speed.
