Continuous data generation with VI simulation.
Is there any method that can generate the data continuously .I'm already seeing the data for the 18000samples that i have in a waveform graph.
I am attaching my simulation of reading spreadsheet  (text files with tabs) and the data that i'm giving.
All i want to do is continuously generating the data by making changes to the imulation.
Is it possible with looping??
Please share your ideas with me.
Bharath.
(2,905 Views)
I'm laso adding the waveform i got from previous VI block.
(2,904 Views)
Hi bharath_reddy,
I was reading your question and I am not exactly sure if I am understanding correctly what you are asking. Are you trying to bring in data from a spreadsheet file and load it onto a waveform graph? That is what your example VI looks like you are trying to do. Or are you trying to continuously acquire data coming from a spreadsheet file and you want it to keep acquiring the new data? If so, you will probably have to finish acquiring the data to the spreadsheet before it can be loaded to LabVIEW. There are some great examples in the NI example finder about using the File Input and Output in the NI Example Finder. Have you taken a look at these examples?
(2,873 Views)
