Continuous signal from virtual channel - novice problems
Hello, I am a novice in LabVIEW and I am trying to build a simple spectrum analysis VI.
I am trying to avoid express VIs, and started by creating a virtual NI-DAQmx and a task for acquiring analog voltage.
wiring all that to a graph, the signal is not nice and continuously seen (it just sort of flashes, tried changing the rate and samples, didn't seem to change much...), and I can't figure out what i'm missing to configure...
Also, I have a question if I wish to use the Amplitude and level.vi or Pulse measurements.vi an error occurs saying that the requested sample was previously available but has since been overwritten, and to solve this I should limit the samples it reads or increase the buffer size - but when I do, the same thing happens.
I really suppose my problem lies in the beginning of acquiring the signal...just don't know where.
I posted the .vi just for clearance.
Any hint? I would appreciate any help.
Thank you
(2,382 Views)
Hi Aneley and welcome to NI Forums!
The main issue with your VI (as I see it) is that you set up the graph's properties in every single cycle. Once I removed the property node from inside the main loop, display was smooth. For simple applications it's better just to use the in-built autoscale, or set limnts only once before acquisition.
The other error usually indicates that you have a buffer overflow, because the loop rate can not keep up with the hardware-timed acquisition. To avoid that, you have several options, please check this paper for further information.
Please get back to me if you need help with anything else.
Best regards:
Andrew Valko
Andrew Valko
National Instruments Hungary
(2,339 Views)
