Continuously Record and Output Pulses from Same DAQ?
I have some sensors I would like to continuously monitor, as well as some projectors I would like to send a signal to at undetermined times (i.e. everytime I press "Play Signal"). Is it possible to independently trigger Analog Output data while continously recording Analog Input data? I am using an NI 6366 USB DAQ.
(2,923 Views)
It should be fine.  Just set up your AO tasks *without* calling DAQmx Timing.  This will leave them in a software-timed on-demand mode.  In this mode, each AO channel could have its own task.  (When hardware timing is configured, most boards would only allow one AO task to be active at a time.)
-Kevin P
(2,902 Views)
Wow, that's some gadget!  [I'm used to its tinier cousins, the USB-6009 and USB-6002).  You use the phrase "independently trigger Analog Output data" -- do you want to output a waveform (an Analog signal) or generate a "trigger", a basically digital output?  The Good News is the device has both AO and DO capability, and it is definitely possible to have multiple DAQmx tasks running simultaneously.
Bob Schor
(2,868 Views)
