Continuously acquire, analyze, and plot data
Dennis
I am aware of the chart history, what I am looking for is to display data in the graph as it is acquired, similar, to real-time.  What is happening now in the chart is the board acquires all the data , then plots it after the run has finished.
Thanks again
Chris
Message Edited by LVhelpME on 01-10-2009 03:22 PM
Message 11 of 15
(2,096 Views)
A chart DOES NOT display all of the data when the loop finishes. A chart DOES display the data as it is acquired. It displays all of the samples you request as far as I can tell. As I said, I cannot run your VI without modifications. I deleted the subVI that does the file read, changed to continuous mode, and made the chart history a bit larger. You still have not attached the text files you are reading. And why would you want to read them with every iteration of your loop?
Message 12 of 15
(2,082 Views)
Dennis
Thank you again for all the help, I think I found a fundamental flaw in what I am actually trying to do with this, and for it, I would not even need the while loop.
I have N channels, N samples being taken, and once those N samples have been taken, the VI will actually finish. I suppose I do not even need the while loop for that. What this whole thread has been working towards has been - is it possible to plot those N samples while they are being acquired, perhaps with buffers of some sort? I appologize for such an ignorant blunder on my part, and thank you again for the help.
Also, I would have attached the text files that you need, but I am not at the computer that has the VI on it now.
Chris
Message Edited by LVhelpME on 01-11-2009 06:24 PM
Message Edited by LVhelpME on 01-11-2009 06:28 PM
Message 13 of 15
(2,066 Views)
Accepted by topic author LVhelpME
I still am not sure what you mean by 'displaying as they are acquired'. The way a data acquisition card works, all of the requested samples are returned at once. If you have a sample rate of 10000 samples/sec and request 1000 samples, every .1 seconds you will get those 1000 samples displayed. If you request 10000 samples at the same rate, every 1 second you will get those 10000 samples displayed. If you are asking if at the 10000 samples/sec rate (for examples), you can have the chart display a sample every .0001 second, then no, you can't do that and I'm not sure why that would be necessary. If you wanted a much slower sample rate (something greater than 1 msec for example), then you could do a single point acquitisiton and display each point as it is acquired.
Message 14 of 15
(2,060 Views)
Dennis
That was quick, I wasn't expecting an answer so late on a Sunday, thanks for the quickness.  That is what I was looking for, our sampling rate is in the neighborhood of 50-100 Hz, but because our application is picky about accurate timing over a long period of time, I would rather stick with the n channels, n samples.  I appreciate all the help you gave me, I am not sure how I could have gotten through these programs without the help of you and everyone else who responded to my posts.
Chris
Message 15 of 15
(2,052 Views)
