Continuously plotting a chart
Hi
I am plotting data in chart continuously over time. My data comes from a VI, that dynamically runs in the background. When I close the VI with the chart and open it again, the chart plots a jump for that time period, in which i left the VI.
Is there any way, to let the VI plot coninuously, even when leaving it in between?
(2,802 Views)
You will either have to run the VI even when it's front panel is closed (so a close just hides the front panel) or switch to a graph and have it get the data from e.g. a circular buffer that you continously update from the dynamic VI.
(2,802 Views)
