I am creating 25 to 30 LabView executable files to run a semi automatic test set. I have gotten all the apps to run fine in LabView, without any inoperability problems. Now I am trying to convert each of the separate vi�s into executables. This also works fine. Each of the programs runs individually. My problem is in running multiple apps that use the GPIB bus at the same time. I am running three Sorenson power supplies. I set them up using LabView.
Error Mode 1.
After I setup the voltage and exit the program, the supplies go back to local mode and reset to 0.
Error Mode 2.
Leave the power supply program active, then open a second program the uses the GPIB bus (but not the power supplies). When the second program ini
tializes the GPIB bus it resets the power supplies with the same result as Error Mode 1.
Using the GPIB spy utility I can see the commands that the LV runtime engine makes at startup and shutdown, is their any way to control the initializing and exit process for the GPIB bus.
