Contour move: Interupt
 Hi ,all
 I have faced several problems when using contouring function.
 Below is the code which I modified from the sample. I load a seire of points and then send to contour move to complete the motion.
 However, I don't know how to intrupt the contour motion. In other words, if something haapens when the contou move is excuting, I want to stop the current countour move and change to another new trajectory.
 Another problem is I cannot adjust the requested interval. The default value is 20ms, but when I change it to 200ms, the error 70078 occurs: parameter out of range.
Thanks so much if anyone can help me ~
Message 1 of 1
(2,836 Views)
