Control Alignment Shortcuts
Why does LabVIEW not support adding shortcuts for aligning controls in the programming environment? These frequently used functions require two mouse clicks each time they are used,
(360 Views)
I don't know why. Maybe because they aren't menu entries.
At least you can use Ctrl+Shift+A for "Align Items" and Ctrl+D for "Distribute Items" (or change it to what you want), which are both part of the edit menu. Both shortcuts will repeat the last used operation.
(338 Views)
Alternatively you can use QuickDrop and create own PlugIn (needs to be placed in C:\Program Files\National Instruments\LabVIEW xxxx\resource\dialog\QuickDrop\plugins\).
Attached VI is "getting started" for Top Alignment.
under the hood:
how it works:
(330 Views)
Or install a VI Package as https://www.vipm.io/package/mnprojects_lib_quickdrop_alignelements/
(311 Views)
When cross-posting from reddit, it would be polite to include a link to the original discussion to avoid duplicate efforts.
(293 Views)
