Control Desing and Simulation Module
I need this toolkit to open and probe and example called: Simulating a Wind Turbine
I installed the evaluation version and it appears activated at NI license manager, but when I try to open the Final Simulation.VI Labview shows that there are some errors and warnings.
Do you have any idea about what is wrong?
I have attached Ni license manager and an error list
(4,447 Views)
Which version of the Module do you have ?
You need the support for LabVIEW 2017.
(4,389 Views)
Hi Cata I finally solve it.
I have 2017 versión, the problem was that It only Works for 32bits versión, now it works
(4,385 Views)
I tried to run the simulating wind turbine file, but i am not able to run.
Its showing a lot of errors.
Can you please help me rectify and provide necessary details to run it.
(2,930 Views)
Hi Hash,
Which errors do you get?
Do you have the needed toolkits/modules installed (like CDS)?
(2,921 Views)
I am using 2015 version, i wanted to know the name of  required toolkits and libraries required.
Please help with the procedure.
(2,906 Views)
Hi Hash,
From the first message in this thread I guess you need to "Control Design and Simulation" (CDS) module to run that example VI.
Do you have a license for the CDS module? (Well, you might install it in evaluation mode and run the example VI for a short period of time…)
(2,892 Views)
