Control FT2232HQmini with I2C in LabVIEW
is there an example to work with an FT2232HQmini in LabVIEW?
The bus is an I2C-bus.
regards, patrick
(2,793 Views)
Accepted by topic author patrick1988
Patrick,
  Believe it or not, I've had this same module sitting on my desk for a few weeks just begging for a free moment.
  FTDI is kind enough to release decent example code for their various chips, although it takes a bit of digging.  The LabVIEW code is located here:  http://ftdichip.com/Projects/CodeExamples/LabVIEW.htm
  I've never used an FTDI chip in a serial bus mode (I'm quite fond of Fifo mode, and the SyncFifo in the 2232H), but it's likely that they're just providing wrapper VIs that call their D2XX dlls.
  I hope that helps!
memoryleak
(2,785 Views)
