Control/ Indicators missing on block diagram
I am unable to locate the control/ indicator on block diagram. They appear as blue line. Can't figure out what's going on.
Please find the attached images.
Thanks!
Message 1 of 12
(3,109 Views)
Hi vrbhaz,
There's only one image. (And there are better ways to create screenshots than to use your mobile phone…)
Why don't you right-click the control and select Find->Terminal?
Message 2 of 12
(3,101 Views)
It appears like a blue dotted line
Message 3 of 12
(3,079 Views)
Hi vrbhavz,
how large is your block diagram? (Tools->Profile->VI metrics)
Message 4 of 12
(3,072 Views)
Message 5 of 12
(3,066 Views)
Hi vrbhavz,
"Show statistics for" "Diagram", then look for diagram width/height…
Message 6 of 12
(3,062 Views)
Message 7 of 12
(3,059 Views)
Hi vrbhavz,
as expected: the block diagram is too large. Point.
(Anything larger than ~16k in width/height leads to block diagram corruption. Your block diagram is 4 times too large.)
Solution:
  • Create a backup of the current code.
  • Delete the current code.
  • Start over from scratch and create new code according requirements while applying good LabVIEW style guide rules.
Message 8 of 12
(3,055 Views)
I have a feeling that this VI is mostly just a sequence structure...
Message 9 of 12
(3,009 Views)
Yes, that's correct. I have lot of sequence structures. I can't avoid them.
Deleting and redoing will not meet the dead line. Is there an alternative solution?
Message 10 of 12
(2,981 Views)
