This widget could not be displayed.
Control Power supply On Off with difference time cycle
I would like to set up the power supply on/off cycle differentiate 2 min on and 3 min off.
(2,864 Views)
Hi Transt,
Ok. And what is the problem?
What have you tried?
Which problems do you run into?
Where are you stuck?
Why don't you attach your code? (Not just an image of a small part of your code, but real code!)
(2,808 Views)
 Hi GerdW,
Attached is the On/Off cycle VI. Right now the code runs ON/Off at the same time. I would like the On cycle longer time than the Off cycle.
  Thank you
(2,790 Views)
Accepted by topic author Transt
Hi Transt,
When the ON time should be different to the OFF time then you should set different timeout values, depending on the current state:
(2,777 Views)
