Control Properties in Array Cluster Array
Hi
I have made 2D array of cluster(cluster of two cluster, which again is a 12 array element). I have attached VI with this post.
What I want to do is individually access properties of the control array.
For example I want to change number of rows for LEDs in Array element (0,0) or completely Gray Out 2nd cluster in first Row.
If I access properties from Front panel, any chage affect all of the control/indicators in 2D Array given here.
Any help will be appreciated
Thanks in Advance
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(2,775 Views)
You can not control array elements independently - only their values can differ
workarounds:
1) Programmatically discard value changes.
2) Several clusters on the front panel and control them via arrays of their references.
(2,767 Views)
