Control Sonoff devices with labview
Hello everyone, Is anyone khow, how can i control my sonoff smartplug with labview? i am using HTTP clients to control the device. But, i have an problem in my URL. can anyone suggest me a URL for sonoff devices?
(895 Views)
Are you looking for their REST API? https://sonoff.tech/diy-developer/
What problem do you have in your URL?
(861 Views)
I have an sonoff plug S26R2. i would link to control(ON/OFF) and observe it with labview instead of ewelink app. can you suggest me, how can i do this? i use http client with url for sonoff device to connect VI with the sonoff device. But it didn't work.
(856 Views)
What exactly did you try? The device is not listed as a diy device on the soneoff page, so it does not have an open API.
Did you flash it with Tasmota or something? You will not see me with a soldering iron around a power socket, but apparently people do that. Then you can use the HTTP API https://tasmota.github.io/docs/Commands/#with-web-requests
(832 Views)
No, i did not try tasmota . is there an another way to do this or the only way with tasmota?
(810 Views)
