Control Waveform Graph - Set Lower Limit and Autoscale Upper Limit
In a waveform graph is their a way to set the lower graph Y limit at zero and then have it autoscale the maximum Y limit as a percentage (150% for example) of the maximum Y graph value ?
Direction to examples or a starting point to read up on would be great !
Joe
Ireland
(3,691 Views)
Accepted by topic author Joe_leen
Turn off autoscale and set the max with a property node based on the array max of the data.
(3,686 Views)
Thank you ! The property Node offers some functionality !
Working on implementing a front panel interactive sliding fft window over measured sound data, We'll be speaking again soon I feel Smiley Happy
(3,661 Views)
