Control When Tip Strip Appears
I am having a problem trying to control when the Tip Strip appears.  I would only like the Tip Strip to appear only when the LED is in a blinking state and at no other time.  I attached my attempt at this. Thanks for your help.
(3,256 Views)
Accepted by topic author MCHammer
you can wire empty string constant to tip strip property in false case.
(3,255 Views)
That did the trick.  Thanks.
(3,250 Views)
