Control a Delta Elektronika Power Supply ES 030-10 using Labview
Dear Gred ,
Thank you a lot for the advices , and I proceeded as you suggested ,
I have just 2 more questions ,
For controlling the Voltage /Current should i use the PWM technique ?
is it possible to generate different kind of output ramps, stairs without using FPGA ?
Message 11 of 14
(1,070 Views)
Hi Mary,
Your device expects analog signals! So NO, you cannot use PWM here…
Why do you think a FPGA would be needed or neccessary at all?
No, you don't need a FPGA - a simple DAQ device (like the cheap USB600x boxes from NI) is sufficient…
Message 12 of 14
(1,066 Views)
Dear GredW,
you said that in order to to generate different kind of output ramps, stairs, i need 'a simple DAQ device (like the cheap USB600x boxes from NI)',
Does this mean that i need to use a DAQ device together with the Myrio in order to aquire/set output voltage/current of the Power Supply?
I am sorry for this basic question , but I found no example of analog programming of a DC power supply using the Myrio , they only use Data Acquisition devises .
Message 13 of 14
(1,049 Views)
Hi mary,
AFAIK the myRIO also brings some AO channels. Use them to control your PSU…
Message 14 of 14
(1,037 Views)
