Control a relay circuit
I have a circuit with four relays and two limit switches. It is used to control a motor to rotate in forward or backward direction. The motor is connected to a cart.
Now I have to program using labview, which i can know how many times the relay have changed its direction or how many times the cart have passed a specific point. After the specific number, the circuit will be shut down. How can it be achieved?
Message 1 of 9
(4,338 Views)
Have you gone through the tutorials? What hardware do you have?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,309 Views)
The hardware is only daq.
Message 3 of 9
(4,295 Views)
I am sure you could be a bit more specific than that.
Message 4 of 9
(4,291 Views)
I am not quite sure about the model. Besides, if any other equipment is needed and the price is affordable, I can go and purchase.
I have only gone through two hour classes in college. However, this programme is very urgent, can anybody provide me an example?
Sorry for inconvenience.
Message 5 of 9
(4,281 Views)
You typically control a relay with a digital output. You probably need an external driver to provide enough current. Digital output, especially static output, is dead simple. There are examples that come with LabVIEW that should get you started. Please attach what you have done so far.
Message 6 of 9
(4,267 Views)
I am using a 24v dc power supply to provide the current. This is the circuit. Now the circuit work well.
My task is just to add a program, so that the program can shows how many times the relay has changed the direction, and shut down the circuit after specific number.
Message 7 of 9
(4,259 Views)
That, for me at least, is unreadable. Please provide a proper schematic and post a jpg or png file. Be a little more professional and do not take a photo.
What's especially unclear is what is controlling the actual operation of your relays. Saying 24 power supply is just not enough.
Message 8 of 9
(4,232 Views)
You've been rather vague so far and that makes it next to impossible to help you.
It sounds like your circuit is already functional entirely, to include the control.  You don't want to control the circuit.  You want to know how many times it's switching and what direction things are moving.  Essentially, you want to log the signal to see when it's 0, +24, and -24 V.  Is that correct?
Once it's logged, you want to be able to determine how many voltage changes you have?
Message 9 of 9
(4,222 Views)
