Control and function pallet
 For some reason my control and function palette's have changed to larger font, how do I reset it? it just goes out of screen when trying to click on it.
Thanks.
CLD
(1,748 Views)
Unfortunately, your picture didn't show the Menu Bar, where the current Font is described.  On my system, it says "15pt Application Font".  Your picture looks like it might (?) be a larger Font.  You can change this as described by doing a Web Search for "LabVIEW font size front panel".
Bob Schor
(1,724 Views)
What is "it" that goes out of screen? Can you show a picture of that instead?
LabVIEW fonts (dialog, system, application) are defined in menu...tools...options...environment. What are your settings?
If you use special scaling in windows (right-click on the windows background...display settings) and see if your fonts are scaled anything other than 100%.
(1,686 Views)
