Control and simulation loop failed to compile
Hi guys ! I tried to insert a close loop for a process , The process worked just fine , but when i inserted a PID control and close loop it failed . It said "Control and simulation loop failed to compile" . Thanks !
(1,403 Views)
Hello
There is too many missing VIs.
Can you archive all the VIs and controls and upload it here? Or at least, upload it one by one.
Maybe I have some missing driver(s), can you tell us what you have used in your project?
(1,335 Views)
