Control bits and join number
When you expand a Index or Replace array they've auto indexed and starting from 0, so you can remove all of those 8 index integers and it'll be the exact same.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(1,019 Views)
  • When you have 8 booleans and they are consecutive from bit #0 to bit#7 then they will form a byte. In this case you can simple use BuildArray to "collect" your bits and replace a block of 8 bits in your boolean array of 16 bits.
  • When your cluster only contains those 8 booleans (in the correct order) you can simple convert the whole cluster into an array.
  • Or you convert the 8-bit-array into an U8 number and join this one with another U8 with value "0"…
Message 12 of 14
(1,010 Views)
@A.Daniel01 wrote:
I just did this:
You can simplify that quite a bit with a simple Cluster To Array.
Message 13 of 14
(995 Views)
Boolean Array To Number has this property:
So you don't even need to explicitly convert to i16.
Edit: Oops, I mean u16 - but you get the picture.
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(992 Views)
