Control desde tablet android de un VI
Hola a todos. Mi idea es publicar un vi con web publisher, si habres IE se descarga el plugin y ya está, pero se podría hacer desde un tablet con Android?.
Por otro lado he intentado acceder a un vi desde firefox instalando el runtime, pero no funciona, incluso usando el google chrome, sólo tomo el control del vi usando IE. Os agradecería un poco de ayuda
Gracias por adelantado
(3,266 Views)
Sorry, I forgot to write in English.
I publicate a vi in a web server with publishing tool. I use IE everything is fine after install the plugin.
If I use Firefox or Google Chrome, i install runtime manually, but it doesn´t works. I need some help with this.
Another thing is if is possible to take control of a published vi from an Android tablet?, I thing is possible to use Google chrome with Android
Thanks in advance
(3,265 Views)
Hi lcaro600,
Would you mind posting your code?  I'd like to see how your setting up your VI.   Are you getting any error messages in Chrome and Firefox?  If you could, please post any screenshots of the error your getting.
Thanks!
Starla T.
(3,218 Views)
