Control device with RS-232 commands in labview
@viCam wrote:
I am also trying to connect with a device via RS232 cable and am able to transmit and receive signal when using hyperterminal but unable to do so using labview.
Can you post your code?  Are you setting the Termination Character in your VISA Initialization function to something other than default?  Is the termination character enabled?  If you are sending \r with your command, maybe you need to disable the termination character enable.  Or maybe set the character to \r, and enable it in the VISA initialization function, and don't put the \r in your command string.  Just send the command itself.  VISA will put the \r in for you.
- tbob
Inventor of the WORM Global
Message 21 of 26
(1,109 Views)
Are you referring to in labview? Because if so I am just starting to work on it. I am not sure I even know where to start yet, since I have done only a little in labview. I will try to post code when I can. If you have any examples or know how to make a program that I could type a string into and have it sent to the device that would be great.
Message 22 of 26
(1,100 Views)
@broken Arrow wrote:
What did you do to get it working?
I got it working by restoring the factory defaults apparently they were off. The flow was set to hardware instead of none.
Message 23 of 26
(1,097 Views)
Sorry, my reply was meant for ViCam, who hijacked your thread.   Go to the help menu and select Find Examples.  Then in the search box type in serial.  You will get some examples.  Study them.
- tbob
Message 24 of 26
(1,088 Views)
yeah...I realized that a couple of minutes later. Thanks though.
Message 25 of 26
(1,079 Views)
That was not my intention. But point taken, I'll start my own.
Message 26 of 26
(1,074 Views)
