Control frequency and amplitude of a loudspeaker.
Hi all,
I'm going to start some experiments using sound waves and I need to control the frequency and the amplitude of a loudspeaker with the following characteristics. Rated power: 1 W; Maximum power: 2 W; Nominal impedance (Z): 8 Ohm; Frequency response: 300–20000 Hz; Mean sound pressure level: 77 dB (1 W/1 m); Resonance frequency: 550 Hz.
I would like to do it with Labview. Can anyone suggest me good references to learn how to do it, possibly avoiding too long or ery general handbooks.
Thank you,
Davide
(4,346 Views)
You will need a pistonphon to calibrate your mic/preamp/ADC chain.
The rest can be done with the build in sound card and an amplifier/speaker
Greetings from Germany
Henrik
LV since v3.1
(4,293 Views)
Hi Davide,
I would start with some of the examples you find in the LabVIEW example finder. Have you looked at these?
To open the example finder you just need to click Help>>Find examples... from any LabVIEW window.
I just searched sound and found 72 different examples which could be useful to you (see attached screenshot)
Kind Regards,
Nathan
(4,265 Views)
