Control graph window
Hi All,
I would like to control the scale of various graphs at the same time.
So you know if it is posible to create a numeric control for the graph windows?
Thanks a lot
(3,248 Views)
you must use "Property nodes" of your graph controls. Rigth-click on them and select "Create->Propery node" from menu. The node will be created on the diagram. Right click on it and go to "Properties->X Scale->..." or "Y scale->...". There you will find a lot of scale properties such as range, increment, stule, format etc. Choose one you want to edit programatically. Now you can change this propery by wiring the appropriate value to the property node. If you need to change sacles of several controls you must create property node for each of them.
Good luck.
Oleg Chutko.
(3,248 Views)
Thanks a lot!
(3,248 Views)
