Control names load from file
Is there a way to load a control (i.e. boolean switch) name from a file?
Here is my situation. I have 4 selector toggles, and a go button. Picking a selection and pressing go will send an array of four binary numbers (true or false converted to 0 or 1) to a sub vi called command_former.
This program is simple. It first loads up a library file with pre-made sequences of bytes which correspond to each button. It outputs an array that includes the appropriate byte sequences concatenated onto one another if the selector toggle is set to 1.
By loading the values from a file, it easily lets the user change what the selector toggles do. But I do not know how to change the name to also load from a file.
(3,031 Views)
Accepted by topic author Macarthskey
You cannot change the name of a control at run-time. You can, however, change the caption. For Boolean controls if you want to change the text that appears in the middle of the control this is done via the BooleanText property node. See https://decibel.ni.com/content/docs/DOC-22669 for a simple example.
(3,026 Views)
That is too bad. But I suppose it doesnt matter either; I dont see any harm in just nameing the switches 0:3.
The captions will work. Thanks.
(3,020 Views)
