Control others panel from one VI
I use to programme in LabView version 4.1 last year. Now I work with 5.1.
I'm trying to find a way to control the status of vi panel, to make them
disappear and reappear as often as I want. For example : I have a main
panel which would call an other vi and make him self disappear, granting the
control to the newly opened panel.
Everything was easy in version 4.1. But now some vi in the Function Palette
have disappeared. What is the feature that replace this functionality?
(2,821 Views)
I believe all of those controls were replaced by the VI Server.
You can use these to do what you are needing.
Kevin Kent
(2,821 Views)
