03-24-2008 10:44 AM
03-25-2008 04:18 AM
Hi Mads,
how do you pass the reference to the sub vi? As far as i know the Front Panel is still there if you connect a Front Panel object to the connector pane.
Hope it helps.
Mike
03-25-2008 08:15 AM
10-15-2008 07:45 PM
This sounds very simular to a problem I am having with very large and complex apps built in LV 8.5 and running under the RTE. I get various referneces (controls, VI refs, queues, etc) that somehow become invalid for no good reason when passed down to sub-VIs. The exe will work fine for a long time but then suddenly it will crash due to one of these type of errors (1055, 1, etc). I have no idea what is going on.
What is worse is sometimes my queue ref will become invaild while a dequeue call is waiting on them. Since I do not call any release queues until the app is shutting down, there is no way this could be happening programatically.
I wish someone at NI would just tell us what is broken in the 8.5 RTE so we could find a workable solution. Should I upgrade to 8.6 ir would that just introduce a bunch of new bugs?
-John
10-15-2008 09:11 PM
New bugs. LabVIEW does not have any BUGS. It has unwanted features. LV 8.6 has its own bugs with references.
