Control references and Page-Controls...
inside the GUI of my program i use two page controls which holds a lot of
other controls and indicators. I created references from all needed controls
for updating inside subVI's. All references i store inside a user defined
control which i use in a seperate VI with a while loop as a global variable.
Cause i don't know how many tabs I need for every page-control, I wants to
add them when necessary.
All works fine, but after adding a new tab i don't have access to the new
one by using create constant of the value property. But when i create a new
reference from the page-control directly , i can set the new tab.
This behavor is really annoying, cause i have to make updates to my global
everytime i add a new tab
Is there any way to solve this behavior?
regards
Henrik
(2,870 Views)
Ok, i solved it...
Henrik
"Henrik Skupin" schrieb im Newsbeitrag
news:9kp1va$sb6$1@news.rz.uni-karlsruhe.de...
> Hi,
controls
variable.
new
> everytime i add a new tab.
> regards
> Henrik
(2,870 Views)
