Control steppermotor via arduino and VISA
I had a program where I could insert an amount of revolutions, rotation direction and the motor speed. This program works perfect, but for my application I would like to change the amount of revolutions to the amount of steps that my stepper need to do. For my stepper 48 steps =  1 revolution. I did change some parameters in the C code and I thought it would work, but it didn't. Here is my code:
last line couldn't fit on my screen it's just  a }
The result from this program is a little strange, the text bellow describes the steps that are done with my input of steps to do.
Steps to do              Steps done
1                                2
2                                6                     =+4
3                                12                   =+6
4                                20                   =+8
5                                30                   =+10
Is there maybe someone who can help me with this problems? I have attached my VI, although I think the problem isn't located there.
(2,687 Views)
What is happening in the motor.step method?  I somehow doubt your want to be putting "steps" as the argument since you are using that for the FOR loop.  A definition of what the step method is would clear that up.
GCentral
(2,672 Views)
I took a closer look to an example code to do 1 step every loop. The example program works, but when I made some adjustments for my application it didn't work. Although it doesn't work I think I'm getting close to make it work. My guess is that there is a little problem with my C code.
When I run my VI it does send a 1 or 2 (clockwise or counter clockwise)  via VISA. But in the C code something goes wrong, instead of doing 1 step in CW or CCW direction it gives me the ERROR status output.
Here is my VI and C++ code:
(2,635 Views)
