'Control terminals on connector pane not on top level block diagram.' comment on CLD report
Hello All
Could anybody enlighten me please , what does that comment mean on CLD report
Does it mean that some terminals are hidden within some case structures and not showing on block diagram without going into case structures or by 'top level block diagram' it means
main.vi and controls on main.vi must also be connected to its connector pane?
Thank you
K.Waris
(3,840 Views)
Accepted by topic author K.Waris
For one thing it means that they run VI analyzer on your VIs since that is a verbatim warning that you receive.  It simply means a terminal which is wired to the ConPane is not on the top level diagram, ie. inside a case structure.
As to why it is often not a good idea to do this read this classic thread:
http://forums.ni.com/t5/LabVIEW/case-structure-parameter-efficiency/m-p/382516#M191622
(3,823 Views)
great stuff
Thank you 🙂
(3,815 Views)
