Control the color of lines on a graph
Using NXG
I have two graphs on a VI. I am plotting different aspects of the same process on these graphs:
Graph A:
Pressure
Temperature
Graph B:
Pressure
Temperature
I want the two "Pressure" lines (on different graphs) to be the same color and I want the two "Temperature" lines on different graphs to be the same color.
Is it possible to control the lines using NXG code in some way? I have looked for properties and don't see it.
(1,520 Views)
Do either of these point you in the right direction?
Programmatically Change Multiple Line Colors on a Chart or Graph - National Instruments
Plot Properties - LabVIEW NXG 5.0 Manual - National Instruments [broken link removed]
-joeorbob
(1,465 Views)
