Control the repetition frequency for HSDIO
I don't know how to control the repetition frequency for HSDIO. Please help. Thank you!
(2,652 Views)
What do you mean by the "repitition" frequency?  There is a frequency setting for the on board clock.  Is this what you mean?  It is set by using the Sample Clock function found in Measurement I/O - HSDIO - Generation palette.  Just wire in a value to the Clock Rate input.
This is a very simple concept, and shows that you are lacking in your understanding of Labview programming with the HSDIO.  Perhaps you should study some examples.  Look under Help - Find Examples.  In the example finder, search for HSDIO.  There are many examples you should study before attempting to write code and before asking questions on this forum.
- tbob
Inventor of the WORM Global
(2,641 Views)
