Control the value of x label of graph with data and time
I'm running 24 hour tests and I'm recording deformation data over time in an LVM document. I already managed to put the values in a graph but I would like to have a line in the graph showing the maximum and minimum of the array values. Another issue is being able to see all the data, I wanted to indicate the start and end date and time. Can you help me?
Message 1 of 1
(1,192 Views)
