Controling a LabVIEW VI from C#
I'm writing a C# program that calls LabVIEW  VI's using the ActiveX automation interface.
Getting started was quite straightforward (Load a VI, set/get simple parameters, run VI, etc...), but I could not figure out how to pass "clusters" from my C# program to LabVIEW...
The help for the "VirtualInstrument.call" method mentions a cluster should be treated as an array of variants - any example available?
I also noticed a "LabVIEWTypes" assembly that seems to have been created to allow manipulation of waveform data types was available- Did anyone experimented with this already?
...Any information would be appreciated!
Regards
(2,913 Views)
I could figure it out ...
In .NET, there are no variants anymore - everything derives from "object" and so we need to create an array of object - each object in this array being a "field" of our cluster.
Let's consider a cluster that contains 3 numeric (double), we would control it from C# in the following manner :
//settings cluster [cluster = array of objects]
object[] myCluster;
//declare settings "cluster"
myCluster =
new object[3];
myCluster
[0] =
new double(); //
myCluster
[1] = new double(); //
myCluster
[2] = new double(); //
//assign values to settings cluster
myCluster
[0] = 3.14;
myCluster
[1] = 1.2;
myCluster
[2] = 2.3;
//Write value to the LabVIEW cluster
myVI.SetControlValue("<clusterName>", myCluster);
Enjoy...
(2,895 Views)
