Controling colors with XY graphs
How can I controll the colors of individual points in e.g. a scatter
graph in LabView. For example if I want to let the color of each point
be a function of a third variable.
Looking forward for any swift answers to a LabView beginner in
trouble....
Per Johan Brandvik
Associate prof., Arctic Environmental Technology
University studies on Svalbard, Norway
Message 1 of 8
(4,113 Views)
"Per Johan Brandvik" wrote in message
news:39524A5D.2923269B@unis.no...
> trouble....
> Per Johan Brandvik
What you want is possible with attribute nodes and some tedious sorting and
shuffling of your data.
A much simpler solution:
Don't use an XY-Graph!
Why not just use an intensity graph? Start with a 2D array of zeroes and
fill in your z-data at appropriate array indices corresponding to your
x and
y values.
Use a nice color ramp for the Z-axis with zero=black.
Cheers
Christian
Message 2 of 8
(4,113 Views)
Christian
Yes, if I had all the data available, sorting into groups and ploting them in a
multiple graph, could do the job, but I am ploting the data in real time as they
are generated.
What I want to do is to let the color of a positional trace (XY graph) from a
GPS system reflect the concentration of some measurements we are doing in real
time.
I am not so attracted to the intensity graph because I need a a rather high
resulution of my GPS trace. Do you have any further suggestions?
Per Johan
or of each point
> > trouble....
> > Per Johan Brandvik
> fill in your z-data at appropriate array indices corresponding to your x and
> y values.
> Cheers
> Christian
Message 4 of 8
(4,113 Views)
For LV 5.1.1 see examples for picture control. Does exatly that.
> trouble....
> Per Johan Brandvik
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
Message 3 of 8
(4,113 Views)
Reinis
As I understand this picture control example you are refering to, you can
controll the colour of the cursor itself or all the point (or the whole
line) in the XY graph. What I want to do is to let the color of a positional
trace (XY graph) from a GPS system reflect the concentration of some
measurements we are doing in real time.
Per Johan
ble.
> > trouble....
> > Per Johan Brandvik
Message 5 of 8
(4,113 Views)
You could use that example and modify it. Also there is a lower level VI
called draw point.vi, it takes x,y coordinates as well as point's color.
Since you can just draw on the picture control without redrawing it, that
should create a scatter plot you want. If you have an array of values
(x,y,z =mapped color), then put draw point.vi inside of for loop with input
being that (x,y,z) array. I attached a simple example, basically a modified
x,y graph pictrue control.
news:39534662.54E1B76E@unis.no...
Reinis
Per Johan
> trouble....
> Per Johan Brandvik
[Attachment Scatter Plot.zip, see below]
Message 6 of 8
(4,113 Views)
Reinis
Thanks, this looks very promissing. This is exactly what I was looking for!! I will
follow this brilliant idea and implement it into my project.
Thanks again!
Per Johan
> Reinis
> Per Johan
> > trouble....
> > Per Johan Brandvik
> Scatter Plot.zip Type: Zip Compressed Data (application/x-zip-compressed)
> Encoding: x-uuencode
Message 8 of 8
(4,113 Views)
Use a multiplot XY graph and use one plot for each color you need. The third
variable becomes the plot index.
Jean-Pierre Drolet
Per Johan Brandvik a écrit dans le message :
> trouble....
> Per Johan Brandvik
Message 7 of 8
(4,113 Views)
