Controling led with prtsc, lwin, rwin, tab and space. (Labview 2024 q1)
Hi, I need help with controlling the LED using buttons on keyboard as in the topic in the keydown structure. I have no idea how to do this. (Labview 2024 q1)
Message 1 of 13
(1,088 Views)
Please don't put your text into code tags when posting.
  • Why do you need five buttons to control a LED?
  • I am not familiar with some of your button names, but I assume these are all on the keyboard.
  • What should the LED do as a function of button action? (on, off, dimmer, brighter, flashing, change color, etc.)
  • Is this a real LED or a virtual LED on the front panel.
  • If this is a real LED, what hardware is used to control it?
Do you have problems with LabVIEW programming, key detection, or with hardware interfacing? You need to explain your problem in significantly more detail.
Maybe start with the learning resources listed at the top of the forum.
Message 2 of 13
(1,081 Views)
Assuming LWIN is the left windows key and RWIN is the right one, many keyboards do not have an "RWIN" so is this a good choice?
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(1,079 Views)
i need to do key detection
i did almost all of the keys with char or vkey in keydown event structure but i cant find any kind of ascii code or vkey in case structure for that buttons
yea sorry for that text in code i used copy paste
I need one button to one led
yep all on keyboard
on/off
its just led in vi
Message 4 of 13
(1,067 Views)
Which one is "that button"?
If you only need one button, why did you mention five? Do you have five LEDs or just one?
Why not show us the code you have so far? (Do "save for previous", 2020 or below, before attaching)
Message 5 of 13
(1,053 Views)
like prtsc to one led, space to second one etc
my code is a mess, im just a beginner and i cat find a solution for my problem
Message 6 of 13
(1,049 Views)
That's why you post your code so we can help you make it better.  Everyone here was once a beginner so we can empathize.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(1,032 Views)
this is the code
i dont have keydown yet
Message 8 of 13
(1,028 Views)
@xBernasx wrote:
code
It is still in LabVIEW 2024 and I cannot open it.
See if this can give you some ideas....
Message 10 of 13
(1,007 Views)
