Controlling Array of cluster elements
@RoopeshV wrote:
I am scanning the machines which are connected with in a local network. List of machies connected are displayed in the cluster elements which are:
1. String1 - Client IP adress.
2. String2 - Client System Name.
3. Connect button
The Connect button should be visible on mouse over of respective array index.
For more information i have attached a screen shot of the vi which i am working.
That is sounding like a bad GUI.  What's wrong with always having the button always visible?  How are you showing who you are actually connected to?
Message 11 of 15
(1,334 Views)
Like it was said previously, elements in an array have to have the same properties. But to show highlight one element in an array over another, you can put in a color box behind all your elements in your cluster. The color box will act as the background of your cluster. Since the color box's color is its value and not a property you can now have different background colors for different elements in the array. Also you can have an event case for mouse move or mouse down? over the boolean in your array and when the user tries to click on it or hovers over it, you can change the mouse icon to tell the user it is disable and actually discard any mouse clicks on that specific boolean. The boolean won't be invisible like you want it though.
Message 12 of 15
(1,327 Views)
If you can make the color transparent when moused over and place it in front of the boolean it might work.
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
Message 13 of 15
(1,323 Views)
3. Connect button
I need to echo that sentiment!  definatly rethink the user story.  just to get you thinking along other ways to implement this than an array of clusters I whipped this out.  It may not have anything whatsoever to do with how your GUI will look/operate in the future but it is something else that a user might find more intuitive
Message 14 of 15
(1,315 Views)
Hi All,
Thank you everyone who has replied on this problem. Considering this is a array limitation. So our requirement is changed, as suggested by
Message 15 of 15
(1,293 Views)
