Controlling Khepera Robot 'Invalid page fault' errors using khepera gripper
have the gripper attached to the Khepera 1 and use the K-Team provided
LabVIEW VI's to control the arm movement or gripper. Every so often I
get an error message after the VI runs and LabVIEW has to shut down.
Does anyone know why this is? I am using LabVIEW 5.0 and the error
message is shown below and in the attached file.
Sam
LABVIEW caused an invalid page fault in
module LABVIEW.EXE at 0137:0076cc3b.
Registers:
EAX=00000004 CS=0137 EIP=0076cc3b EFLGS=00010212
EBX=00000074 SS=013f ESP=01a6fd68 EBP=01a6fd74
ECX=00000001 DS=013f ESI=0323c498 FS=31bf
EDX=000000f4 ES=013f EDI=00000000 GS=013f
Bytes at CS:EIP:
f3 a5 5e 5f 59 8b e5 5d c3 57 06 1e 66 8e da 66
Stack dump:
0323c498 030b5b31
00000000 01a6fee4 006b4f21 0323c498 00000000
00000004 030b5b30 00000007 0323c0bc c10745e4 01a6fdd8 bffa4633
03076ece 03076e44
(2,665 Views)
I had no idea what you were talking about until I searched Google.
The company K-Team manufactures the khepera robot.
I recommend contacting K-Team to see if they have seen the same
problem. You can attempt a reinstall of LabVIEW and possibly the OS
if they have no information. If you would consider an upgrade too
(LabVIEW is made better every release). Go to
http://www.ni.com/labview/ and download the LabVIEW 7.0 evaluation.
This way you can see if the problem persists.
(2,665 Views)
