Controlling LabVIEW program for MCP BR2827 LCR meter
I'm looking for LabVIEW controlling program for MCP BR2827 LCR meter
if someone can help I will be grateful,
Thank you very much
(4,036 Views)
Hello Chamslo,
To control this kind of device, you'll have to use RS-232 or GPIB port.
In order to do so, LabVIEW give you access to VISA API.
You'll find below a white paper talking about instrument control
https://learn.ni.com/learn/article/getting-started-with-instrument-control-hardware-and-labview
Here are some examples.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex/q/visa/
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,993 Views)
Dear Sabri,
thank you for your kind reply,
actually I'm looking if someone has already done the program so that will save me time,
Thanks a lot
(3,989 Views)
Chamslo,
You should try Visa example.
Which port are you using to control your device?
Best regards.
(3,986 Views)
it is GPIB port
(3,972 Views)
Il vous faut alors une interface matérielle GPIB.
Vous pouvez installer le driver NI 488.2 qui vous donnera accès aux exemples NI de contrôle d'instruments par GPIB.
http://www.ni.com/download/ni-488.2-3.1/3619/fr/
Cordialement.
(3,967 Views)
