Controlling SP-2155 Princeton monochoromator
In our lab we use a Princeton monochromator model SP-2155 to acquire different spectra.
In order to set up and control the monochromator Princeton provided a software called SpectraPro, which performs very well.
However, SpectraPro is a closed program, which hampers its integration to other devices and instruments using LabVIEW.
Princeton also provided a library of VI blocks (SITK, third party), which can be employed to build customized, more complex VIs.
We need to develope a VI, which approximately emulates SpectraPro.
Regretfully, we are not LabVIEW experts and it is not easy for us to employ SITK simple blocks to achieve that goal.
Has somebody developed a VI, which permits the control of a SP-2155 (or similar) Princeton monochoromator in the same way SpectraPro does?
I really will appreciate any help you can provide.
Martin
(4,330 Views)
Hey MartinSAN!
I found some drivers for SpectraPro...you might like to take a look into them:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=3086
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0497A9B9817E3506E0440003BA230E...
Other users have also built some for SpectraPro:
https://forums.ni.com/t5/LabVIEW/How-to-write-a-LabVIEW-code-for-Acton-SpectraPro-500i/td-p/66227
What communication protocol does your monochoromator uses?
-Andrea G
(4,279 Views)
